New and Used Wire Decking in Plantsville, CT
Wire Decking for Pallet RackSized to Your Beams.
Standard channel decks for step beams, flared channel for structural and box beams, and in-step decks for hand-stacked loads. Shipped nationwide.
What Wire Decking Does on a Pallet Rack
Wire decking is a welded steel mesh panel that sits across the front and rear beams of a pallet rack level. It turns two beams into a shelf. Pallets that hang off the back don’t drop through, cartons and loose parts have something to sit on, and a broken pallet board doesn’t send product into the flue space. Most warehouses add it. We sell it new and used, and we’ll quote it with your rack or on its own for rack you already own.
Commonly Stocked Sizes and Capacities
| Deck Size (Depth x Width) | Fits Frame Depth | Channel Style | Waterfall | Capacity (Uniformly Distributed) | New or Used |
| 42 in x 46 in | 42 in | 4 channels, 4 ga wire | Front waterfall, 5.5 in extended rear lip | 3,000 lb | Used |
Used decks come in as we buy out buildings, so the mix changes week to week. If your size isn’t listed, call and we’ll check what’s come in.
Three Deck Styles, Three Beam Types
Match the deck to the beam, not the other way around. Mesh opening, wire gauge and channel count change the rating from one deck to the next.
Standard Channel
U-shaped support channels run front to back and rest on the step of a step beam, the common roll-formed beam on teardrop rack. The mesh wraps down over the beam faces (the waterfall), so the deck can’t walk forward and pallets slide on without catching.
Flared Channel
Box beams and structural beams have no step. On a flared channel deck, the channel ends spread out and bear on top of the beam instead. If you run structural rack, this is the one you want.
Sizing Decks to Your Beams
Measure the frame depth first, outside of front column to outside of rear column. The deck depth matches it: a 42 in deep frame takes a 42 in deep deck, and the waterfall drapes over the beams on both sides. Then measure the beam length and the beam profile. Two decks usually fill one bay side by side, so the deck width is roughly half the beam length. Check whether the beam has a step. A step beam takes standard channel or in-step, and a box or structural beam takes flared channel. Send us those three numbers with your pallet size and weight and we’ll match the deck. On used rack, measurements and a photo of the beam end tell us more than any label would.
Capacity Ratings and Direct Loads
A deck’s rated capacity assumes a uniformly distributed load: the weight spread evenly across the whole deck, with the pallet bearing on both the front and rear beams. That’s how the number on our table is stated.
A load that doesn’t touch both beams is a different case. A crate set in the middle of the deck, a pallet turned sideways, a machine part on its feet: these are direct loads, and a deck rated for a given weight won’t necessarily carry that same weight as a direct load over time. Our own example from the floor: for 2,500 lb pallets placed as direct loads, the manufacturer’s engineers specified 3,500 lb wire decking. If your loads sit like that, tell us when you ask for a quote. Direct-load jobs need the manufacturer or an engineer to confirm the deck, and we’ll get that answer before anything ships.
Used decks carry A&A’s own conservative rating.
Decking and Rack Safety
Decking catches a pallet that’s been set short or has a cracked bottom board, which keeps product off the aisle floor. It doesn’t replace pallet supports or a load sign. Load signage and rack labeling are the customer’s responsibility; A&A doesn’t supply them.
New or Used
Used decking is the lower-cost way to fill a building. Ours comes out of warehouse buyouts. New decks make sense when you need a matched count in one size or a firm ship date.
Photos From the Yard
Most decking orders go out with rack. Our pallet rack sizes and capacities page lists the new uprights and beams we keep in the yard, and the used racking accessories page covers end-of-aisle protectors and the rest of the add-ons.
Shipping
We ship wire decking from Plantsville, CT to buyers nationwide, including the states below. Send your zip with the quote request for a freight number.
Delaware
Maine
Maryland
Massachusetts
Michigan
New Hampshire
New Jersey
New York
North Carolina
Ohio
Pennsylvania
Rhode Island
South Carolina
Vermont
Virginia
West Virginia
Our Google Reviews
FAQ
Wire Decking Questions
Do I need wire decking on pallet rack?
Not always. A full-size pallet that sits square on both beams doesn’t need it. Most warehouses add it anyway, for overhang, mixed loads and broken pallets.
Will used wire decking fit my rack?
It will if the depth matches your frame and the channel style matches your beam. Send the frame depth, beam length, a photo of the beam end and your load weight, and we’ll check the fit before you order.
Do you buy used wire decking?
Yes. We buy wire decking along with the rack and other equipment when a building is being cleared out. See we buy used material handling equipment or call 1-800-826-5326.
Is wire decking required by fire code?
Not by name. Fire codes care about how open the shelf is, and wire mesh is the usual way to keep it open. Ask your fire marshal about your building.
What are your hours?
Monday to Friday, 7:30 a.m. to 4:00 p.m. Eastern. Call 1-800-826-5326 or send a quote request, and we’ll confirm the order by phone.
Ready to Order or
Have Questions?
Our team is available Monday–Friday, 7:30 a.m. to 4:00 p.m. EST. We’ll confirm your order by phone after you submit.
